I've already found some:
The speedo gear cable should be clamped in the rear left corner.
Service manual mistakes
- Capture.PNG (157.24 KiB) 1246 mal betrachtet
Zuletzt geändert von ronenfe am 4. Feb 2018, 23:07, insgesamt 2-mal geändert.
Re: Is there a thread with service manual mistakes?
The black line goes to the front hole, together with the screw, and the screw in the front should be in the back.
Also there are 2 screws that are missing completely from the diagram, painted in orange.
The long spacer and bolts should be at the bottom and not at the top.
Re: Service manual mistakes
I've never checked the parts reference for mistakes. What I know of are:
- There's an omission in the owner's manual. It does not contain a service interval for the swingarm protector. It should be checked at least as often as the chain has to be replaced.
- One other mistake I know is an inacurate torque reading in the service manual. I remember a thread where somebody destroyed a screw because of this, I cannot find it though.
You are talking probably about the rear shock lower bolt torque, same mistake as the dr.
It's too high.
http://drriders.com/shock-removal-t7492.html
http://drriders.com/service-manual-erro ... 16293.html
Sorry for posting it in the wrong topic. Please move.
It's too high.
