Seite 2 von 2
Re: Scrambler aus Finnland (leider auf Englisch)
Verfasst: 9. Jul 2022, 20:49
von Melitos
Soso hat geschrieben: ↑6. Jul 2022, 21:41
Ok I won the auction, the carbs should be at home by the weekend. I have nearly rebuild the bike and I have the felling the next step will be to strip it >:->
Good for you! Please start your own thread for your project to keep things "in order". I'm sure there will be interest from others for your adventure in fitting a pair of RS34 to the Freewind.
Yes there are some Yamaha singles with 66mm carb spacing also. Perhaps they have more space in the frame for larger carburettors. FCR33 is the largest of "small size" Keihin FCR. 35 and above have larger outer dimensions but seem to have been fitted to some Yamaha singles. However I am not sure if they fit inside Freewind frame. Also the standard Freewind carburettor has outlet outer diameter of only 38mm so it can be challenging to fit RS34 with 40mm outlet outer diameter to Freewind manifold.
Verfasst: 13. Okt 2022, 19:42
von aGentleFreeWinder
These rubber protectors of the front fork, how to get one fitting on the standard xf650?
regards!
Verfasst: 14. Okt 2022, 08:52
I got mine from ebay, there's a wide range available fitting our 43mm fork tubes.
Verfasst: 14. Okt 2022, 11:21
Verfasst: 14. Okt 2022, 13:01
Since I don't order anything from amazon I can't really comment on the quality and flexibility of those fork boots...
I didn't fasten the lower end, but you could cut out a part around the fender to make it fit smoothly around the fork.
Verfasst: 14. Okt 2022, 15:55
Ok, thank you for your responses!
Verfasst: 14. Okt 2022, 19:48
von Melitos
aGentleFreeWinder hat geschrieben: ↑13. Okt 2022, 19:42
regards!
I got mine from ebay. They were for Harley Sportster. Enduro fork boots are much longer typically and I did not like that look.
Fit to fork:
- 20180202_222103.jpg (39.39 KiB) 3037 mal betrachtet
You may need to grind the ends of this fork brace / front mudguard bracket so that the rubber fits between fork and the connector plate.
- 20180114_115418.jpg (72.67 KiB) 3037 mal betrachtet
Verfasst: 14. Okt 2022, 21:11
Melitos hat geschrieben: ↑14. Okt 2022, 19:48I got mine from ebay. They were for Harley Sportster.
So were mine!
Melitos hat geschrieben: ↑14. Okt 2022, 19:48Fit to fork:
Love the idea! I never thought about doing it this way... I was basically thinking about doing a cut-out around the entire brace and not just the parts where it's screwed onto the fork... this might be something to do over the winter (in case we get one).
Verfasst: 16. Okt 2022, 12:31
@Melitos
Thank You! That is a clever solution!
